My 1995 L3 Basket case Ninja resurrection gets ever further refined, and with the last hurdle of diagnosing a completely shot air filter element (fitted new at the beginning of the reassembly stage 5 years back!). Now we have an "about town sociability" and a smooth 1000-3000rpm progressive acceleration! Trouble is that I have now inherited another problem and this is Starting From Hot. I say "hot" but it is really after cutting the motor for 5-10 minutes, it restarts immediately on a stop /start basis using NO accelerator and restarts easily again after being left for 20-30 mins (but again using NO throttle at all to initially fire it up), but trying to start it on a hot engine after a 4-5 mins. stop is just impossible!
Referring to some other "Ninja" period related posts (mid 90's models) it appears that I'm not alone with this type of problem? One owner commented on a sticking Emissions valve issue on his ZX10, the valve connected to the Carb breather circuit appeared to be faulty? He explained how to eliminate this valve from the system.
I decided to experiment and as explained, plug the vacuum take-off point on the inlets, Plug the Airbox hose entrance from this valve in the airbox and then removed the valve assembly itself and route the Carb breather pipe to atmosphere (behind the Carbs and in the space over the gear box /clutch housing area). My bike, when reassembled started as normal.
When out on a test ride I immediately ran into problems, I had a bike that wouldn't accelerate through mid-range and needed choke applied to accelerate past 3000RPM. Something strange was happening.
The following day I back-tracked and RE-INSTALLED my Carb breather emissions valve set-up. The result was a complete return to normal and engine throttle response giving effortless and smooth acceleration, throughout the Rev- range.
Whilst I had this emissions valve assembly off and in my hands I decided to try a couple of tests. With the help of a second person I found that the valve was indeed functioning But it activated when I BLEW through the vacuum hose ( and this closed it). With atmospheric pressure or a vacuum applied it stayed open. I remain perplexed as to what in fact this valve achieves, how it functions and why my bike runs great with it connected, but runs shite with it removed from the system (with carbs vented to atmosphere).
Any hints as to what I'm doing wrong in trying to eliminate this emissions garbage from the system, and also why my bike hates starting when hot and left for 5 -10 minutes, would be greatly received.
