I've got the X-TRE and running 6th gear timing values in all gears and we like to think on the 07/08 the butterflies are opening because of the very noticeable increase in the intake noise in the first 3 gears. Let's not get hung up on that. Not the mission here.
How can you add more total timing advance short of adding another $325+ dynojet timing module which the way I understand it you can program timing in each gear which kinda throws the X-TRE out the window.
In my case it would be great if you could somehow just bump up the overall advance 6, 8 maybe as much as 10 degrees. Only a dyno will tell. I've read that these bikes love more advance to the tune of the upper teens of HP instead of just the 14's.
XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
END This discussion. No way other than the Dynojet Module to do what needs to be done so continuing this thread is useless.
