Hi everyone,
I am new here, i have a old zx-750L 1995 for 2 years now.
Run fine until a couple of months.
The idle speed when the engine is warm is at about 500 rpm, almost stall
When i have the choke on until it is warm the idle is moving up and down every seconds for about 300 rpm (1000 -1300). this behavior was not there 3 months ago.
Yesterday i was at cruise speed (60 Mph around 5000 rpm) and suddenly i loose power on and off. I was on the highway when i turn to my exit and had to slow down, the engine stop. Pull over check if i have gas in my thank (ok on this). Try to restart the engine and it is starting normaly. I was able to get at home. Weird thing when i arrive at home i let the bike run at idle speed and the idle speed was back to normal around 1000 rpm.
Today try the bike again, start normaly, idle speed ok (1000 rpm)
Go for a ride a have again the loose of power at cruise speed and when a increase the throttle, i feel the hesitation of the bike.
Do you have an idea what the problem can be ?
Thanks in advance for your support
