21 - 22 of 22 Posts
You might add some fuel stabilizer (Motul for example, sold in Motonet etc.) to help starting up after Winter storage. I would change the fuel in the tank because water can cause corrosion in fuel tank and block even the carbs, jets etc. Warm storage doesn’t help either.
New fuel in and stabilizer is my advice :) And in Spring I recommend a carb sync and tune-up in some professional workshop which you have plenty in Vantaa and Helsinki area.
Discussion Starter #22
Thanks for the tips :) I added some fuel stabilizer, before I put the bike cover on. If I will have problems in the spring I will change the fuel. Fresh is always better.
21 - 22 of 22 Posts
