1 - 13 of 13 Posts
Hello. I recently got kawasaki zxr 400 (1992) and it was always bit slow to start. I haven't ridden for 2 weeks and now it's not starting. I recharged the battery and it sounded bit stronger, but still wouldn't fire up. It sometimes tried to start and stays on for split second, but won't stay on. Yesterday I got one loud pop from the exhaust. What could I do? I'm really noob when it comes to mechanical stuff.
Are you using choke? Along with jumping from a non-running vehicle, it should be light enough to try and push start as well. Turn ignition on and choke, push it/have someone push you/go down a hill and pop it into second gear, then release the clutch.
Discussion Starter #4
The choke doesn't do anything, but the last owner made some cable which is hanging from right side and by twisting it, I can adjust the idle RPM
I'd say a carb clean and balance is in order. Are you able to test the battery? Might need that replaced too
Discussion Starter #6
The battery seems fine but yeah I would guess it's the carbs. That's something I can't do myself though :/ I wonder how expensive it would be for someone to clean them
Discussion Starter #7
I wonder if I could change the spark plugs myself, but I haven't found a proper guide for my bike
Discussion Starter #8
Little update: Today I charged the battery once again, but this time it took bit longer, I don't know why, maybe the battery got more voltage than usually? Anyway now I got it fired up and instantly as it turned on I gave it gas so it wouldn't die out, because it would otherwise with cold engine. Once it got warm, it just stays on nicely. So that's nice. So could it still been just the battery?
Seems like you have a few different things going on. When you say the choke doesn’t do anything, do you mean it’s broken or it doesn’t affect idle speed? And that cable you mention...the last owner made it? Because every bike I’ve ever owned has had one to adjust idle speed; pretty sure all carbed bikes have one. Are you saying it’s not the stock cable?
Giving your location might be helpful, maybe someone local can come check it out and possibly shed some light on the problem(s).
Discussion Starter #11
Oh they made those cables from the factory? I thought only my bike had it. I used to have enduro bike before and it didn't have that cable. Yeah the choke does not affect idle speed, no matter in which position it is. I live in Finland so I really doubt any locals here. Would be great if here was though.
1 - 13 of 13 Posts
