I bought a 96 zx7r last June with 10000 miles at a good price. The bike is in perfect condition. The only issue I have been having with it is that when I shift from 1st to 2nd and very rarely from 2nd to 3rd at high rpms it will grind gears a bit. This never happens when shifting below 7000. I know that if I press very hard and quickly on the shifter it will lessen the chance of grinding but it is still and issue as I do want to get yo the root of the problem. Is this normal for the zx7r? I bled the lines today. I noticed the oil was very old. I am also thinking it might be a clutch issue. If I start the bike on 1st with clutch pulled I will feel a jerk. Also, then the choke is on the bike won't want to go into first from neutral, it will grind gears till the choke is off. I am sure the clutch is the original. Do any of you recommend a certain clutch for my bike? I have seen information on clutch kits. Is that what I need? Or do I just need the plates?
Thank you
Fizz
Thank you
Fizz
