was having trouble switching ignition on due to wear so bought a replacement from china on ebay for a fraction of the cost of dealer.
had to swap wiring on new switch (6 wire + brown) with my old wiring (5 wires) to get it to work. screws to access wires had to be drilled out as original switch was fitted with 'breakoff' heads.
switch was also fitted to triple clamp with 'breakoff' heads so had to remove triple clamp (4 x hex + 36mm nut) in order to drill out screws. bought new m6 x 20mm screws to replace.
seats, tank and airbox had to be removed to to access wiring.
