Hi just purchased a ZX7R and noticed the the 6mm hoses on the air valve and the air valve switch are missing . Where do I need to connect the hoses too as the manual doesn’t show ?
cheers
Most will just throw the emissions crap out. Plug the 4 intake nipples, connect the two hoses on the cam cover and run the carb vent line into the air box.
If you search Kleen Air delete and vent bowl mod, you may find diagrams to explain.
Hi thanks , but bike is bogging down when under load and I wanted to eliminate all reasons . I’ll def be removing all the emission parts once I’ve resolved running issues .
cheers
Does it rev when not under load? If so, the likely cause is the ram air system. You need to have the float bowls vented into the air box if all that emission crap is unhooked.
Hi yeah revs cleanly when stationary . When on the road under load it bogs down and won’t Rev.
