Does anyone know for sure if the 95 zx750 will bolt up the same as the 02 zx750 motor blow and looking to see what all will work
7777
You will need something like the BRG ZX9R kit. Upper mounting bolts are in the wrong place, an airbox adapter and a oil drain plate with hose.
The top right bolt may be in the right place, but the top left is off
7777
BRG will not know if it fits. But hell, the guy is such a tool he has the year fitment info for the ZX9R wong also. The kit should fit but you will have to play with the upper two bolt adapters.
I didn’t understand the post. It seems like he is asking if 95 and 02 are the same mounts. The simple answer in my books is no.
A lot easier to find a spare 96-03 engine for sale than to retrofit a 95 to the 96-03 chassis. Not worth the time and unlikely you will come out any cheaper in the end.
