1 - 20 of 24 Posts
7777
All parts are for ZX7/ZX7R unless marked. All prices not including shipping. Buy a bunch, get a better price!!
Click on thumbnails for bigger pics
Muzzy exhaust with crappy Ti can $300
Muzzy exhaust - rare high mount - with aluminum can SOLD
Dymag wheels for 96+. Rear black magnesium with sprocket, front gray mag center, polished aluminum center. $500
09 ZX10R swingarm including spacer for left side ZX7R (still need to make the other spacer) SOLD
Custom bracket for ZX10R swingarm with Ducati Brembo rear master cylinder. Includes KTM/Brembo rear master cylinder. Works great with above swap. $200
96+ ZX7R carbs $100
91-95 Keihin 39mm carbs $400 (need a good cleaning and gaskets)
91-95 Keihin 39mm carbs that can be used on a stock airbox (SOLD)
Custom 91-91 ZX7 triples, black anodized with ZX7R logo $300
04-05 ZX10R Ohlins shock (can be used on an 96+ ZX7R without mod) SOLD
06 ZX10R triple with modified 636 upper so it can be used on a ZX7 $50
96+ aluminum fairing stay $60
Custom titanium/aluminum rearsets 91-03 $200
96+ Attack adjustable triples $400
91-95 hugger (random white paint on there that could be cleaned) $40
91-95 hugger $80
91-95 R model close ratio transmission $400
96+ headlight $200
91-03 Braketech rotors $300
93-95 aftermarket solo tail SOLD
96+ ZX7R left side tail SOLD
96+ ZX7R right side tail (pic above) SOLD
91-03 Gafler rear rotor $50
96+ brake and clutch master cylinders with levers (carbon look) $50
96RR Nissin front six piston calipers $200
96RR motor including close ratio trans 16K miles SOLD
96RR swingarm SOLD
96+ gauges showing 16373 miles $50
96+ subframe SOLD
96+ intake tubes, left and right $100
91-03 rearsets, left and right $150
91-03 Muzzy rear suspension linkage $400
96+ Factory Pro roller shift lever, new in box $50
R model exhaust hangar $50 SOLD
96+ fairing and headlight brackets $100
96+ radiator and fan $50
Kyle Racing adjustable 50mm clipons (will not fit ZX7, need a 10R swap) $100
96 Fiberglass upper and side fairings painted yellow/black SOLD
Pitbull rear stand for spools $100
Pitbull rear stand for spools or swingarm $120
96+ Tokiko 6 piston calipers $50
96+ left and right controls $100
96+ 41mm FCR with airbox adapters (these need fixing and some parts) SOLD
Just so it is clear, I have more than a full time job, I am slow to respond, but will get you your parts.
I will get some more pics up soon.
Scott
Oh my fuck I need more money...
I want the high mount, the RR motor, and the rims... Dammit. Shipping would kill me though.
I might be in for the carbs. How are they set up? Also, you don't happen to have a coolant temp switch laying around do you? Dealer wants like 70 bucks for one.
BUMP- for an awesome guy!
Great member to work with.
7777
Radiator switch or the thermostat? I know I have several radiator ones around here.
I have access to a shipping company now (recent shipping all but killed me). I bet I could get a decent price. I just send a full pallet to Denver and it was not all that bad.
Both FCRs are for 91-95s. Don't you need P carbs? They both have 155 jets.
Scott
7777
how much just for the upper fairing?
Really just looking to make them all go together. Being fiberglass they all fit together well, but not exactly the same as stock. Not sure they would work with stock fairings.
7777
I can't believe nobody caught the multiple 06+ ZX7R comments above. I guess it was a little late when I created the list!!
Mckinleyville, CA. Does the sun come out enough to ride there? I have a lot of family from there. Beautiful place though. I will give you a call.
LOL sun in Mckinleyville
Yes occasionally we see the sun here. We just ride in cold weather gear even in the summer. Thanks, looking forward to your call.
Larry
7777
Ok. Back from playing in Hawaii.
PCPRO99, I will give you a call
Therion, if I had one I would keep it. I think I only have one spare here in Cali. I will check if ****** has any, which as I remember he has a ton of them.
Scott
Yeah, need P-Model stuff, and the switch not the thermostat. My fan doesn't come on any more unless I jump the connections. I PMd you.
Do you still have the following?
Dean
1 - 20 of 24 Posts
