1 - 8 of 8 Posts
ok so im in the process of putting it all back together, i put what i think were the correct plugs into the coils and all that (this shouldnt matter should it?) and im also trying to start it, but everytime i do it just turns over but doesnt start, but when i stood it up straight it popped and smoked for a second then back fired once....do the plug wires have to go into the coils a certain way? like 1 and 2 together and 3 and 4 together or 1 and 3 together and 2 and 4 together? and what about the lil plugs that go into the top of each coil? yes i know ur supposed to fill it up but i didnt i, did still use stabil though
let me add that the popping is like a pop with a ppppssshhht like air escaping really fast then smoke and i smell gas or something
The wires for the #1 and #4 cylinders come off the same coil. #2 and #3 come off the same coil. You also need the coils plugged into the correct feed wires. Otherwise you'll have what you're experiencing.
What year is your ZX7 and do you have the shop manual or the wiring diagram for it?
its a 94, yeah i remembered the the 1 and 4 thing and 2 and 3 thing but yeah ill have to work on actual wire to back of coil thing cause i have like seafoam colored wire and black wire, no read adn black or whatever....no manual
wait just realized i do its just for a zx7r.....should still be the same though right?
Lol of course they have to be in a certain way, firing order is kind of important.
yeah i found it...its black wire to 1 adn 4 coil green wire to 2 and 3 coil then each red to each coil, started right up....smokin like a mfo though hahahahahaha
Mine smoked like a bastard for a little while too. Might be a carb setting or maybe just blowing the crap out of it from sitting.
1 - 8 of 8 Posts
