1 - 20 of 22 Posts
my friend blew a rod on his 01 zx7r mint bike except for the motor.i can pick it up real cheap . my cousin has a 99 zx9r motor from a bike he wrecked. i know you can put a 95 96 zx9 motor in a 7 frame can the 99 motor be put in using one of the motor mount kits companys have for sale or it is different thanks
you should definately do that, and hit me up with that frame info so i can get my beast started and get you some money to get that project goin... i've always wanted to do the 7/9 swap, but first things first with getting my bike back together...
do you happen to know if the 98 motor will work? i found a 98 zx9r motor , and i own a 95 zx7. I want to do this swap really bad! lol any help would be appreciated.
The 98 is the same as 99 zx9. This is very doable. What you would have to do is move the motor mounts down farther on the frame. The mounts on the zx7 are in front of the cylinder jugs and behind the jugs on the zx9. The 94-97 is more of a drop in. The motor mounts are in front of the jugs but they are of by a few mm. The only problem with the is they are becoming harder to find. I think that once someone dose a newer 9 conversion it will become as popular as the older 9. The newer 9 has more power potential and a larger supporting market.
I am using Miccrosquirt. It is all installed i just have a few more things to fad and weld up. I am also having communication problems with it. For some reason my laptop will not connect with the ecu. It has dto do with the usb cable i just have to figure it out.
If i remember, they came from a 99 zx7. I also have 99 forks and brake wave rotors. A lot of tokico calipers are the same. You can get them from a bandit, gsxr, tl1000, zx9, zx7 and a few others. Here is a good site for using the on the older zx7 forks http://homepage.ntlworld.com/webzxr/zxr750r/ .
That's exactly some of the stuff I was looking for, too! Excellent...
1 - 20 of 22 Posts
