Does anyone know where I can get a mount or a kit to re-position the liscence plate? I removed all the plastic off the back and I want to mount the plate under the seat toward the back tire. Any suggestions? :headscratch
search kawiforums.com. I don't like the majority of fix's out there though. Some relocate the plate completely under the seat next to the rear shock and it is only visible from directly behind. I just kept my plastics and bobbed the fender leaving only the plate hanging from the pipe bolts.
If you have a look at the bracket that bolts onto the exhaust which holds the two plastic sides together, you can cut the two hook like sides off and then bend the front of it down. You can then either bolt or use double sided tape and stick it on there and it is still under the pipe. I had mine on for about a month and it worked and looked cool but then i just scrapped the plate and dont ride with one at all
