Before starting this build i searched high and low trying to find someone else who had done one, with no luck.
so i joined zx forums to start this thread..heres where im upto so far
this is what is was
raised rear subframe and front fairing chop (if anybody wants to know how to raise the rear just ask and ill post more detailed pictures very easy)
then i designed how i wanted the rear to look on my computer just using MsPaint
then i marked out what i designed and cut the fairings
iv decided that while im going to the trouble i might as well rebuild the engine and gearbox, you can see in this phot where i have relocated the overflow to
then i had to cut and trim the front of the rear fairing so that it lined up to tank now that it is all on different angles, trial and error just doing a small bit at a time.
then i had to cut the seat down and retrim it so that it would fit on its now shortened base
im currently relocating the battery so that the section under the seat will be clear to see through
this is what is was
