. When I am at a higher speed in 6th Gear or 5th gear and get off the throttle it jerks just for a little bit , is that normal ? it only has a thousand miles it acts like it doesn't want to slow down give it more throttle and it's just fine
Sticky throttle cable(s)/throttle?
very loose chain can cause a jerking feel when let off at speed
  • Like
Reactions: 92Ninjas
Yep. Just be careful if you're going to tighten it up. Too tight and uneven will cause strange and bad things to happen
