21 - 40 of 47 Posts
Discussion Starter #21
Yes I down the valve cover and the engine is on perfect scars on the crank and cams. Then I push the whole cylinders and they dont moved but the compression on the 3 is 80 psi and 4 cylinder is 0. Next week I will down the head and send it for checking
Discussion Starter #22
Today I looked in the cylinder with micro camera and I think the problem is with my piston. There is a little peaces from him. Left side is a little broken. When take out the head I'll send photos with the damages.
7777
At least it's #4 to inspect with the cam cover off. It's a bitch to get that cover off. If all looks ok on top get a fiber optic camera down the hole. There could be a hole in the piston. Another trick is to put in a compression tester in there and hook it to an air compressor. Then get a harbor freight stethoscope to see where the are is escaping. Out the throttle bodies is a valve, out the exhaust is a valve, sound in the crankcase is a piston.
Discussion Starter #25
Okey. The result from the test with the compressor. I heard a sound from the exhaust and I smell the gasoline evaporation. The next is a sound from the oil cap when open it. So I think the piston and the valve are damaged. I hope weekend can down the engine and get out the head and see whats happend.
Discussion Starter #28
The moment if true boys. Holes in the piston because there is a curve valves. Can I change the piston if I open the oil container
Discussion Starter #33
The valve head is off, but the cylinders are there. I will just pull the cylinders and I can work on the piston. In the manual is shown like that.
Yer you can remove the cylinders which gives access to the pistons easy enough.
Metal fragments will have contaminated the lubrication system so they will need flushing out and the Oil Pump inspected for damage while your at it.
Discussion Starter #36 (Edited)
Hi all, after research for the problem it seem to be bad clearance or didn't make it never, two broken valves makes the holes in the piston. The repair is in progress. I ordered the gaskets, and send the valve head for repair. I'm waiting to come gaskets to assemble everything. In one, two weeks I'll be ready and new photos will be post.
Discussion Starter #39
Hi guys. The rebuild is still in progress. Today I took the head. The master made it like new, new valve seals, refreshed valves, cleaned and 0.1 mm head grinder. On Friday the bikes goes to the workshop. Next week wait for the first start after а big waiting. Кeep your fingers crossed everything to be good and to finished everything soon. New videos and pics soon.
Discussion Starter #40
Hi guys. The motorcycle is ready. It claimed a new cam chain, valve adjustment, fresh oil repsol racing full syntetic 10w50 , new coolant Hеpu green, new sparks. Now I can't hear the motor. It works so smooth and quiet. I will post video soon. Thanks to all for the help.
21 - 40 of 47 Posts
