97 ZX11D which is running hot. As in, it gets up to operating temperature, does fine on the highway, but as soon as I get back down to 30mph stop/start driving or even worse, traffic jams, the fan is running almost constantly and the temp gauge needle climbs up to a little over halfway. I don't recall it running this hot before. And this is in the relatively cool (40s to 60s deg. F) weather recently.
I recently refilled the overflow reservoir which was very low; I'm not smelling any coolant when I'm riding it though. There is no water in the oil, and my oil level is normal, so I don't think there's a cracked jacket. I swapped the radiator cap for another identical one but it made no difference. The fan is coming on, which I believe means that the thermostat is working, since the fan switch is located on the bottom ("out") side of the radiator. I replaced the fan switch last year when it failed which is the last (only) time I messed with the cooling system.
My guess is that the water pump is not functioning or only partially functioning, which is leading to the water circulating very poorly or not at all. Before I replace the water pump (I have a spare donor bike I can try before buying a new one) am I overlooking anything? Any suggestions what else to check?
Cheers
Cheers
