Hey Guys, I dropped a hex nut down through the oil fill hole on my 1999 ZX11. No luck retrieving it yet with a flexible magnet. The factory service manual says to remove the engine if you want to remove that particular cover, which is called the Gearshift Mechanism Cover. Have any of you been able to remove that cover without removing the engine? I see that the water pump overlaps it, so that has to be removed. Any help is greatly appreciate. Thank!
Have u tried to get the bolt thru the oil filter hole?
