Muzzys is the first to offer a Steering Damper solution for the ZX-14. The race quality damper unit features a speed sensing design which changes damping resistance based on the rate of movement. This allows for normal light steering at low speed where larger steering inputs are used while providing a higher damping force when required at high speed. Fully adjustable, 22 levels of damping are available for a perfect feel in any condition. The nitrogen filled damper resists foaming of the damping fluid and gives a constant feel regardless of temperature. The hard chrome shaft resists corrosion.
The black anodized mounting hardware is CNC machined from aluminum billet and very simply bolts to the chassis. In addition, a hinged fork clamp is incorporated for quick and easy installation without dropping the fork tube. Highest quality hardware is used throughout. Installation requires no special tools and takes less than 30 minutes.
