Hi all! I just found this great site and registered. I ride a '92 ZX-11 C3 and need to replace transmission gears, forks, drum. Would a "D' transmission be an upgrade? ZZR tranny, ZRX 5 speed. Are any of these swaps possible? Thoughts?
btw that d model with the 12r forks and 7r swinger looks sweeet!
p.s. glad to be here!
A transmission from a D model is a perfect fit into a C's engine. But you need to know those two point:
1-you must swap the assembled shafts as a whole; not individual part or gears over C's shafts or vice-versa.
2- You need to use a D's front sprocket along with a D's output shaft (or, of course, a C's front sprocket along with a C's output shaft). D's output shaft is longer than C's and both sprockets are made accordingly to fit on their respective output shafts.
If you respect those points, it's a direct and perfect bolt-on.
Thanks for the info Claude and Ozzy. BTW my avatar is my 4th overbore H2 engine mocked into my 1990 ZX-7. It's a long term project. Not completed yet. Waiting on $$$. I need to find a more or less permanent host to upload pix to, as in dogpile etc.
