I WILL BE UPDATEING PICS AS THE DAYS GO ALONG. MORE TO COME!
Picked my baby up in April, 2011 from a pregnant woman who could no longer ride anymore. Bike had right under 2K miles & was completely stock. I had an unfortunate low side last october and since then been getting her road ready. She now sits at just under 14K & runs smoother and more responsive then ever. I Literally put blood into this bike. Countless times i felt like i was going to lose a finger or a hand even. I have already gone thru a whole box of dora the explorer band aids & glad the pain is finally over. This is my first bike that i ever really worked on, so hope you guys enjoy and Ride safe,Thanks!
Fluids
Amsoil SAE Full Syn 10W40
Amsoil Coolant/Watter Wetter
Motul RBF600
Maxima 10W
Aesthetics
Custom Paint Job
Custom Painted Rims
TLS-MD3-12 (Being installed)
Decals Removed
10,000K HID's W/Relays
Dual High-Beams
LED Flasher Relay
LED Front Indicators
LED Integrated Tail Light (Smoked)
Euro Flush Mounts (Smoked)
No-Cut Frame Sliders
Double Bubble Wind Screen
Reservoir Sweatband
Shaved Rear Reservoir bracket
Radiator Guard
Fully Adjustable Rearsets
Zx-R Bar Ends
Carbon Fiber Tank Pad
TechSpec C3
Zip-Tie Plate Mount
LCD Mount (DIY)
Aluminum Keyless Fuel Cap
Pro Bolt Clutch Cable Adjuster
Blacked out
- Headlight Housing
- Engine Case Cover
- Stator Cover
- Passenger Pegs
- Exhaust Hanger
- Brake Calipers (Front/Rear)
- Raiditor Sides
- Front Rotors
- Rearsets
Performance
ECU Jumper Mod
Zip-Tie Throttle Mod
Kleen Air Mod
Block Off Plates (Kscouc)
Servo Eliminator
Shorai Lithium-iron
Battery Cable Extensions
EvoMX Tank Foam
BMC Air Filter
K&N Oil Filter
SeaFoamed
NGK Iridium Spark Plugs
Heat Wrapped Fuel Line
Heat Wrapped Air Box
Carbon Fiber Yoshi RS5
PC III USB W/Custom tune
LCD Display for PCIII
SpeedoDRD W/Recall
Adjustable Shorty Levers (Clutch/Brake)
Braided Steel Lines (Front/Rear)
Nissin Caliper Swap
Carbone Lorraine Pads (Front XBK5/Rear RX3)
Superlite Sprockets (Front/Rear) (-1/+2)
520 Gold Chain
Rear Brake Reservoir Delete
TB's Sync
Valves Adjusted
Factory Pro Stacks
Factory Pro Evo Shift Star
Ceramic Wheel Bearings
Manual CCT
MP Throttle Cable
MP Clutch Cable
MP Washer Lock
Forks Revalved
RaceTech Fork Springs
RaceTech Rebound Fork Valves
New OEM Bushings
New OEM Fork Seals
Lowered W/Suspension Tune
3-Way Lowering Links
Resurfaced Rotors
Schnitz Radiator Cap
Magnetic Sump plug
Pirelli Rosso 2's
Dyna Beads
Uploaded with ImageShack.us
Fluids
Motul RBF600
Maxima 10W
Aesthetics
Custom Paint Job
Custom Painted Rims
Decals Removed
Dual High-Beams
LED Flasher Relay
Reservoir Sweatband
Radiator Guard
Zx-R Bar Ends
TechSpec C3
Zip-Tie Plate Mount
LCD Mount (DIY)
Blacked out
- Headlight Housing
- Engine Case Cover
- Stator Cover
- Passenger Pegs
- Exhaust Hanger
- Raiditor Sides
- Front Rotors
- Rearsets
Performance
ECU Jumper Mod
Kleen Air Mod
Servo Eliminator
Shorai Lithium-iron
EvoMX Tank Foam
BMC Air Filter
K&N Oil Filter
SeaFoamed
SpeedoDRD W/Recall
Nissin Caliper Swap
520 Gold Chain
TB's Sync
Valves Adjusted
Factory Pro Stacks
Manual CCT
MP Throttle Cable
MP Clutch Cable
MP Washer Lock
Forks Revalved
New OEM Bushings
New OEM Fork Seals
Resurfaced Rotors
Magnetic Sump plug
Pirelli Rosso 2's
Dyna Beads
