ZX900A1 spark plugs
First off, my battery had died, so I left the bike running for a few to charge. I left it too long, and it overheated a bit. So now it has to turn over a TON before it will start, and it feels like 75% of what it was. I figured I may have fouled the plugs.
I picked up some NGK DR8ES, which take an 18mm socket. When I try to remove mine from the bike, however, the socket does not grab. I have tried 5/8, 11/16, 3/4, 13/16, 16mm, 17mm, and 18mm sockets. Since I need to remove the tank to get in there, I cannot just ride it to the tool store and match it up. And since the plugs are recessed I cannot measure them. I removed them once before at a friend's house, but I cannot remember what type of socket I used. I suspect it has something to do with the bevel on the inside of the socket and the same on the outside of the plug not allowing grip, but that's just guesswork.
Has anyone else run into this problem?
