21 - 40 of 47 Posts
Discussion Starter #21
Thank you!
She comes along fine i think
Yes the GPz had these problems with the starter clutch.
Had to rebuild this on my other gpz a few years ago.
Good tip for anyone owning these bikes
The also suffer from bad oil pressure in the top end. Pitting of the camshaft.
And i think also i heard about oil passages to crank nr 3 beaing blocked and destroys crank bearings.
But these bikes were groundbreaking in design and performance, so there are bound to be some faults.
Skickat från min moto g(7) via Tapatalk
Discussion Starter #22
This is my other GPz.
1989 , My fathers old one, i grew up on the back of this
120000kms, all stock parts.
The black 900R looks superb also.
The oil pressure issues can be solved by fitting the later ZZR11 oil pressure relief valve to the oil pump (1998 onwards). Kawasaki up-dated the oil pressure relief valve to a piston type plunger and 4 holes, instead of a ball type and 2 holes. The Kawasaki part # is 16130-1058.
I did this on my ZX10B and I see no reason why this part would not fit the 900R.
My ZX10B also has pitting camshafts, I have even heard that this was a problem with the later ZRX11/12 so why Kawasaki let it go so long is beyond me. The attached picture scared the shit out of me when I took the camshafts out to inspect them. But I have accepted it for what is is. The engine is 31 years old all the others will have the same problem, so getting replacements from other engines wont solve anything. Getting the camshafts repaired, ground etc is just too expensive.......may as well ride on until she eventually blows!!!
Looking good.
Have you considered replacing the mirrors?
I found the original mirrors next to useless on mine, all I could see where my elbows. The later 900's had the same mirrors as the ZX10B and I find these mirrors are excellent.
GPz900R late model mirrors
Discussion Starter #28
Thank you!
This is a later model, i put the old mirrors on because i think they look better but yes the old ones suuuuuck
Discussion Starter #29
Got some parts back from powdercoating.
Was not sure about the colour of the rims. But the more i look at it the more i like it.
Discussion Starter #30
Wheels and swingarm almost done.
This project is killing me...
Nothing is going like i plan.
Waiting for parts like never before.
And the powdercoater did not mask up all the holes. Wich sucks. Tapping and trying do polish paint off takes forever.
Spring where are you!!!!!
Hang in there.
I know it is a pain to tap holes which should have been protected. But a t least you will know the threads are how they should be,
Discussion Starter #32
Could not find the can i wanted for decent money.
Bought a cheap stainless to modify.
Still need to make it 2"ID and move the mount, sand the welds.
I think either glass blasting use an orbital sander.
I use to work making stainless beer tanks and that is what we use to do.
Discussion Starter #33
I was not happy so i made another endcap.
Beadblasted with glass.
Tomorrow there will be a full day welding midpipe and brackets.
Getting close...
Discussion Starter #36
Thank you.
Hoping to get some better pictures when it is completed
Discussion Starter #37
Took the bike out for a wash today.
Had to hear som noise
Have som small jobs left to work on.
Not sure what to do about the front fender.
New seat and some decals will be done shortly.
Uploaded a small video if anybody is interested.
Discussion Starter #38
Spent the day buffing my garagepaint.
Pretty happy with the result.
And put some decals on.
Waiting for a front fender and seatcover.
Spring is around the corner.
21 - 40 of 47 Posts
