i recently bought this bike not running...i replaced the starter relay and the mechanic said it was good to go...i drove it home a nd now it wont start...turns over sometimes..im getting just a knock under my seat...tried to jump it but no go....please need some feedback..
Make sure all your battery connections are clean & tight. I just now thought if you had to replace a relay to get it started the first time, maybe something is causing that relay to fail after you get it started. I'm not a mechanic but these are some things you can try & think about.
try unplugging and replugging the connectors into your junction box, wont cure it but should help
btw that is cronic problem with these bikes, 10 bucks says that if you pick up and tap your relay up against the sub frame it will turn over as well, welcome to the club...
