Just looking for any tips or a link that shows how its done. I've ordered the harness specially made for our bike so the install will be easier. Thanks for any help.
I have - what would you like to know? What bike?
I installed one on my 05 636. Do yourself a favor and purchase the adapter. It makes life easier. I placed mine on top of the exhaust valve servo under the rider seat. The only thing I had to modify was the plastic on the underside of the seat for clearance. Love the alarm but my only bitch is that the battery doesnt last in the remote.
I'm putting it on my 07 zx-6r. I just want to know any tips or tricks that make the install easy. I just want to get it done right.
I used some extra lengths of wire to get into the fuse box at the front of the bike for the ignition kill. I tapped the line going to the ignition fuse. I highly recommend these: http://www.webbikeworld.com/Reviewed-motorcycle-products/posi-lock/ in the waterproof variety (find them at your local Kragen or Pep Boys). I used a fish tape to route the wires along the main harness back up under the tank into the under-seat area to the back of the bike.
I sat the perimeter sensor on top of my battery with the included velcro, and the ignition kill relay on the left side under the seat. I mounted the alarm unit under the seat. I cut out the tabs at the front and front sides of the underseat tray with a Dremel to give more room for the cables. I passed the cables underneath the bracket that mounts the rear seat / solo cowl. The perimeter sensor isn't as sensitive as I would like at the stock setting, but it can be changed. I haven't got around to it yet. Default if anyone gets right over the bike it starts to go off, but I'd like it to beep if people are in about 6 feet or so.
I don't know which remote you got but I have the TRS-6B which is the black rechargeable waterproof remote. I find it lasts about 4 days before it needs to charge, but the battery shows low LONG before it is dead (wait to charge it until it says pager off is what I do). It will work when it's charging so you can always plug it in and then disable the alarm if you need to. My bike's only alarmed at home, I work at a secure government facility so I don't worry about her there.
Hope this helps.
