Guys I've just bought a 2004 ZX10R. The guy I bought from had fitted a set of R1 Calipers which I've yet to look at/overhaul.
Any idea the likely year the R1 Calipers came from..I'll need to look see if theres a part number on them.
Cheers in advance.
Stu
Sent from my SM-G975F using Tapatalk
That is the best upgrade you can do for a 04/05 Gen 1. Please post a pic of the caliper to get a better idea of what year R1 it’s from.
Any 108mm caliper will fit.
I have Nissin ZX6R calipers on my 04.
17301
Discussion Starter #3 (Edited)
Just saw this reply apologies, for some reason I'm not being notified, of course I should have posted images at the time it always helps.
I since sussed out the calipers are from a 2004 model.
I purchased a set of 320 Brembo discs and caliper bolts with the extension kit and a caliper seal kit, theres a Brembo M/C in situ so I'm thinking the end result should be pretty decent.. the discs are considerably larger aesthetically.
That looks a clean machine mte mine is slowly coming together.. it's not been well looked after...and pretty shabby, so decided on an overhaul starting at the rear and working forward.
