1 - 20 of 51 Posts
Hello. I like to wrench on things.
In this thread, I will try to revive an 05 zx636r.
In the end I hope to have something suitable from anything from straight havok to a simple ride to the 7/11
18897
Yes, I could there Kev, however then I would have nothing to do.
Today, I began wire brushing some of the salvageable parts that had 10 years of spray paint and grunge on them.
18898
Hello @Alumicraft145. I tend to use a military style backpack with molle system that suits most of my needs when Im out and about.
As far as as 7/11 goes, ive literally lived off the food there at some points in my life. Good times.
Today, I scored some nice track fairings from a stuntrider down the block for a full fairing/stunt look in the end.
The bike looks assembled, however it is not even close to being assembled and is just "mocked" up while I get a vision of what I want, order parts, and pray to the bike Gods
that it runs.
Cheers bro.
18899
Discussion Starter · #11 · (Edited)
Sometimes, you go gamble on a bike and the engine is toast
This time, the seller was 100% honest. I guess there are a few decent people left in these here parts
First fire! Its all downhill from here.
Might be a while until I post again, no need to post boring tedious work
I made a "sanding disk" for my drill... took one of those velcro sanding pads and glued a cut out of vegetan/raw leather to it.. added some autosol (marine shine) and then used that to polish some dull bits and pieces to a high chrome looking finish..
Works like a bomb :)
Discussion Starter · #18 · (Edited)
I have a long way to go with airbrushing. The quality of the airbrush is crucial. Time to upgrade.
to do list;
--------------------------------------------source gauges-done
--------------------------------------------source caliper bolts-done
--------------------------------------------source tank bolts-done
source dual caliper bracket
source delrin slider material
--------------------------------------------source rectifier-done
--------------------------------------------source chain-done
--------------------------------------------rebuild and reupholster seat-done 1HR
--------------------------------------------source exhaust can- done
--------------------------------------------source fairing bolts-done
--------------------------------------------source footpegs-done
fabricate axle pegs
source projection headlight
--------------------------------------------paint wheels-Done
-------------------------------------------fabricate cage-done 6 HRS
-------------------------------------------fabricate subcage-done 3 HRS
-------------------------------------------fabricate stunt stay- done 4 HRS
-------------------------------------------clean and inspect calipers-done 1HR
-------------------------------------------wire brush frame-done 3 HRS
-------------------------------------------repair wiring harness-done 2HRS
rebuild forks
------------------------------------------Diagnose rich condition/hunting idle-done 4 HRS
------------------------------------------diagnose charging system short- done 1 HR
------------------------------------------source/change tire-decided to run these dirt bike tires for a while.
------------------------------------------paint and body----half done 8 HRS
optional;
------------------------------------------new airbox-repaired
power commander
1 - 20 of 51 Posts
