as above.
Guys,I believe he is looking for the gear driven oil pump used with the gear drive assembly used with either the Suter dry clutch (which is what I think he's looking for) or with the gear drive assembly that replaces the cam chain on race bikes. The standard oil pump is driven by a chain .just buy new oem, the 7's oil pump runs metal on metal and buying used is a huge gamble. the oil pump is located on the same shaft as the water pump which is driven by the alternator chain inside the clutch compartment, not next to the oil filter (that is the oil cooler).
I have one of the kit oil pump gears for the wet set up utilizing the chain drive. I will pull it out of the parts bin and count the teeth for you. That might help a little.can any help me out with some info need the o/d of the two gear and also the amount on teeth on both gears.
Do you have the part number?the one im after is for the gear driven, mesh type gear no chain used its the same as the one in the kit manual if this helps
Now I see what you're looking for. The complete part numbers are:part #59051 and #13216
just need the o/d and amount of teeth,that would en great or better if you know any one with them for sale??...i can make the rest up to use the gears.
