Tips for working on your bike
For starters:
When removing/replacing your fuel tank:
a. put a rag under the front of the tank & over the frame tubes to protect the paint from damage
b. place a block of wood (2"x2") under the back of the tank to make it easier to disconnect the fuel & vacuum lines & any electrical connections.
When removing the rear wheel get that bit of 2"x2" or whatever thickness suits & slip under the tyre. This allows you to take the rear spindle out without the wheel dropping and makes it easier to line things up to get the spindle back in.
