Got this info off ZX14.net
Engine Type: 4-Stroke, 4-Cylinder, Liquid-Cooled, DOHC, 4 Valve Cylinder Head
Displacement: 1352 cc
Bore & Stroke 84.0 x 61.0 mm
Maximum Torque: 113.5 lb-ft / 7,500 rpm
Compression Ratio: 12.0:1
Fuel Injection: DFI with Mikuni 44mm Throttle Bodies (4)
Ignition: TCBI with Digital Advance
Transmission: 6-Speed
Final Drive: X-Ring Chain
Rake/Trail: 23 degrees / 94 mm.
Front Wheel Travel: 4.6 in.
Rear Wheel Travel: 4.8 in.
Front Tire Size: 120/70 ZR17
Rear Tire Size: 190/50 ZR17
Wheelbase: 57.5 in.
Overall Height: 46 in.
Overall Length: 85.4 in.
Overall Width: 29.9 in.
Front Suspension: 43 mm Inverted Cartridge Fork with Adjustable
Preload, Stepless Rebound and Compression Damping
Rear Suspension: Uni-Trak with Adjustable Preload, Stepless
Rebound and Compression Damping, Ride Height
Front Brake Type: Dual Semi-Floating Petal Discs with 4-Piston Calipers
Rear Brake Type: Single Petal Disc
Fuel Tank Capacity: 5.8 gal.
Seat Height: 31.5 in.
Dry Weight: 474 lbs.
Color: Passion Red, Ebony, Candy Thunder Blue
MSRP: $11,499
Wheelbase: 57.5 in.
MSRP: $11,499
