I'd like to get my upper triple T either chromed, or powder coated. Problem I am having is that the back of the ignition switch is catching on the oil seal edge as I raise the T. I could drop the lower T, but then I would have to support the front of the bike, and would have to remove the upper two nuts. I am hoping to avoid loosening them, because I don't want to re-set them.
Here's the question - can the oil seal be slid up past the two upper nuts without damaging it? - or - does the inner edge of the seal go under the lower nut?
Any brainstorms out there? It does not have an immobilizer, but the switch is held on by the break off bolts.
i dont understand whats catching? i just took my triple tree off and its getting powdered right now..
r u sure u have the key in the unlock position so u can get it off? then all u need to to is drill off the rivets of the key ignition.. and it all comes right off..
When I got my LSL handlebar kit it came with a chrome upper tree.
Craig
