need help my right turn signal isnt working both the front and back side,ive checked the fuse it looks fine..id appreciate any help
its working now.....its the turn signal lever or whatever its called?was corroded i sprayed it with wd40 and its working now,thanksdid you check the bulbs?
I think wd attracts dust might want to get some electrical contact cleaner!its working now.....its the turn signal lever or whatever its called?was corroded i sprayed it with wd40 and its working now,thanks
+1 on the Electrical Contact Cleaner. WD40 will definitely do more harm than good in the long run (take it from me...I know :banghead)I think wd attracts dust might want to get some electrical contact cleaner!
