yeah, turn the key to 'on' and nothing. no neutral light, cluster lights, turn signals, won't start.
Not the battery, checked w/multimeter, and other direct-wired components work
Not the ignition fuses, neither the one in the box or in the solenoid clip-on.
Yes, it's in neutral
Yes, i tried push starting in the 120 degree vegas sun, 4 times.
Battery terminals are corrosion-free.
Rode yesterday for a couple hours, and jumped on today to go for a ride, and this. Could an ignition just take a crap over night, with no outside force to help it?
its a 97 7R, i know it needs a starter solenoid, but i get nothing from the dash. i also spliced into the radiator temp sensor wires to put a switch for manual control of the fan, but i cant find a relevant connection that would cause the ignition (?) to be completely out. im having a meltdown
check block connectors on main loom under airbox , these may be dirty or corroded , sounds like what happened to my zx11 after leaving it for a few days ..
hope this helps ?
