21 - 24 of 24 Posts
Thermostat doesnt tell you anything, thats for sure, it just keeps engines WORKING temperature on point, if its stuck closed engine will overheat, if its stuck open not a big problem, almost same if you would take it out, the problem will be not with overheating, but with overcooling on colder day or on highway, that would cause faster engine wearing.
hello guys i tried to remove my thermostat my bike runs cooler then ever but its not a good idea to removed because when the air flow is not hitting the radiator very well , th temp will clamp up, so the over heating will occur when you are in traffic or tunnel or highway when there is a vehicle in front of you blocking the air flow , so its a fucked up idea to remove the thermostat :)
21 - 24 of 24 Posts
