I have a 01 ZX9R and I wanted to put a 02-03 tail section on it I wanted to know if any knows if I have to change the sub frame in order to make it work?
I believe they afre the same but i would check with your local dealer or go to bikebandit.com and compare thje part numbers betweem the two subframes.
You will have to get new front and rear seats if you do the changeover. Seats are slightly different between the years.
to upgrade to the F model tail you'll need:
-subframe
-front & rear seats and mounts
-tail fairing
-battery tray
-oem undertail/fender or aftermarket undertail
-optional solo seat cowl
if you go to the kawasaki.com site and lookup th parts catalog, you see what parts and #s you'll need. plus, make sure all the hardware is the same.
