i Have the integrated tail light that comes with the two brothers exhaust..n i got pulled over other night because my tail light is out..but my brakes still light it up...i checked the fuse and chased the wires everything all good..is there a relay for the tail light somewhere or anyone have any ideas..07 zx6r...thanks in advance..
If its LEDs, then no idea. If not, The bulb(s) are shot.
Just stop at the auto parts store and buy an 1157 Sylvania super bright bulb. The filaments on a bulb will break then sometimes they will touch at the break and light up again. The offset pins are there for a reason. They orient the bulb correctly, if you reverse the contacts you'll have bright tail light and a dim brake light. Then it makes you look like some dumb ******* in a Ford truck.
Banned
Should be LED on that bike.
are you getting power up to the light? If so either it's a bad connection or a bad light.
If not it's something else along the system. lol
Try using jumper wires to hook the light directly to the battery.
