1 - 8 of 8 Posts
Ok here's the deal.
I got a Competition werkes FE and after install and connect everything the tail light does not come up. neither the led Lic light .
the turn signal are ok. Im pretty sure that i connect the correct cables.
Blue to blue
Red to Red
Black/yellow to Black/yellow
So what could it be?
Let me know guys, cause i will die if i don't ride
Discussion Starter · #2 ·
no one?
could it be because i turn the bike on before i attached this cables ?
the fuse might went bad?
where's the fuse box?
If the wiring colours are the same as an '06 636 then:
BK/Y should be ground
R should be tail and licence
BL/R should be brake
Main fuse under the left side cover '06 636
Fuses under rear seat
gammac
fender eliminator
i priced one of these for my 07 zx6 and was going to cost about 70 pounds prob nearly 100 dols so thought id make my own two L shaped brackets from a hardware store cost me 2 pounds no plate light 8 pounds looks great and waiting for a company to make a rear tail light that has indicators built in (turn signals) so i will have the normal stop light but with led indicators built in looks better and cheaper than fender eliminator neat tidy and no stupid indicators on the back
do you have a picture of this one installed, im looking around to find which one to get
1 - 8 of 8 Posts
