How is this done on an 06 ZX6R... I know on most bikes, you can take off the little shift rod and just flip that one piece over, and its done, however, you cant do that on the 06 ZX6R because there is something in the way, and the rod wont reconnect.. Do you have to buy anything, has anyone done this???
If your factory shift knuckle won't allow you to do it then you will need to purchase a set of rearsets. $300 -$500 range. The 07's allow the change with no problem and $0
I swear you can do it on the 05-06 models without doing anything special.
Just flip the linkage at the engine around. You may need to put a spacer behind the shifter so the shift rod doesn't rub the frame.
Although this is with the rearsets moved from the OE position I seem to think it works in the OE position. Unless the shift linkage is too long in the OE position?
