This chick backed her SUV into my 07 zx6r while I was BSing with a friend when stationary and not paying attention. She was going a few mph and hit the pillion peg, the bike was going down but I managed to save it so I was all "its no big deal (funny what a hot girl can do)." A few days later I noticed the pillion pegs didn't look aligned, I took the ass apart a bit and decided to replace the plate that holds the whole pillion foot mount on that side, it looked off. When it arrived I compared the two and my original from-the-factory-piece was very clearly bent. Be glad for cheap aluminum, right?
Wrong. It doesn't spec up to the subframe. I know the original was fucked from its bolts, they are skewed bad (thanks again, cheap aluminum). I had a couple of extra bolts in my toolbox and the subframe is def. bent like 25 degrees. I loosely set the passenger peg, and that is how she sits.
Some say that if I mount her (the bike, chick is gone) to a bike trailer and put a reverse twist on the subframe I might be able to correct the negative torque, but if the frame is that fragile I don't want to do that. I can also get a stock piece off of fleabay for cheap, but I'm concerned about supporting bike thieves.
Those are your only two options unless you want to buy new. If it were me (I'm an aircraft mechanic with a full sheetmetal fab shop at my disposal) I would attempt to straighten the old one. If it straightens up and there are no tears in the metal, I would use it. If there are tears and you have a friend/relative/acquaintance that welds aluminum I would get it welded. If said welder does it for free I would definitely float them money for a case of beer. You might need their services later and you want to stay in their good graces. But that's just me.
Thanks, that is what I wanted to hear (try to fix it) and I appreciate your background.
I probably exaggerated the degree of bend. The local forum seems pretty good with people willing to help for food/beer and I have access to the trailer & come-a-long. Maybe get a piece of scrap steel to use as a torsion bar and some steel bolts. I'll look for cracks and integrity on the sub. Thanks again.
lol for bumpfire.
Damn liteweight aluminum!Maybe they should build em out of solid steel.:tard
You'll see what I mean if you lay it down with enough speed or find a mishap such as mine. And aluminum is a rigid metal, this is aluminum alloy. Not complaining as this helps keep cost down, but it does make for a more fragile motorcycle. There was a good article in one of the motorcycle magazines recently (motorcyclist or sportrider) about how a frame can get bent with only a minor fall: it is a price to pay for a lighter machine.
