hello i was wondering if any one has a vacum hose diagram for the routing from the carbs to the tank /petcock i cannot find it any wher any help wil be greatly appreciated i got it as a project bike and the tank and carbs were off
As to the normal routing of the line I can not help however I also do not think that it is that critical either. Although it will work fine if attached to either intake, it is usually from the number two intake vacuum nipple between the carb and the head to the petcock. route it anyway that you need to to avoid pinching it and it should work just fine.
there is two smal nipples on 1and 4 on the intake are they suppose to tee off and run to the petcock ?and also the two bigger nipples on the carb side are they just over flows?
ok so 1 and 4 are running back to the pollution stuff so can i run 2 and 3 to the pet cock would that be the same thanks for any help
You only need to run one to the petcock and I would just cap the other.
