I hit a concrete block on the road and bent the front wheel, and pushed the steering cam stop up on the bottom of the triple clamp. Do you think I bent the forks, and how do I tell if there bent???
If you can, drop the forks out. Support them on blocks of wood or "V" blocks so they are level; picking the smooth bits of stanchion and slider and rotate them. You should see any woops. Being able to do this with a dial gauge would be good.
gammac
