has anyone ever had to replace the stator cover on an 05 636 before? and if so then how difficult would it be to do. do i need to drain the oil first to do it or is it simply a cover plate. any help would be appreciated.
pretty basic, just take out the bolts arround the cover and pull it off (may not slide ride off due to the magnets so be affraid if u have to use some mussle) and then just replace it with the new one. You should pick up a new seal for it as well and make sure u remove the old one and clean the gasket surface really well. You don't need to drain oil but some might poor out when u unbolt the cover. Just top the oil up after when you're all done if need be. thats pretty much it. PM me back if u have anymore questions
