i'm trying to learn about what changing the sprocket can do for my wheelies, and wether or not i'll lose any mph on the bike? if you guys have some info i would appreciate it!
By dropping one tooth on the front sprocket you will lower your gear ratio. Making the bike reach it power range more quickly and want to lift the front wheel skyward much more easily. However by performing this action you will cause a decrease in your top speed by 5-7%. Also by changing the gearing you will reach redline much faster causing you to shift if you are riding them for any distance.:crazyloco
