1 - 11 of 11 Posts
'95 zx7, speedometer reading way higher than it should. When it says 70, my gps reads about 55. It is not erratic or anything like you would expect with a bad cable, acts perfectly normal. My front tire is stock size as well. What could cause this? Gauge calibration off? It does sit at zero when stopped.
VP Whoring
Sprockets changed out?
Mine is 10% off, but if you have a larger than stock tire on the thing it screws you a little bit too, but not that much.
Sounds like you just have a huge error. You can buy mechanical speedo units for calibrating those things, they go inline on the cable. They are a pain in the ass.
If I were you I would just get rid of the speedo and use the GPS in its place.
Are you sure you have the stock sized tire and not a 120/60 or 120/50?
Josh
Even a different tire manufacturer, of the same size, could have a different rolling diameter but not enough to give that big of an error. Only other thought is about the housing at the wheel being stock/repaired.
Does it match closer with the GPS at lower speeds and get worse at higher speeds.
Have you checked the GPS against any other vehicle?
Uhh, all speedo error should do that unless the needle is physically in the wrong place.
The reason being that speedometer error is a percentage, not a fixed difference.
Discussion Starter · #10 ·
It's got a 120/70/17 just like factory
The gps is correct, its about dead on with my car's speedo and it shows my trucks speedometer to be about 10mph off at 70 (oversized tires). I can't use it permanently though since its my cell phone lol.
And yes, the error seems to increase linearly as you go faster. I'm guessing its a problem with the gauge, anyone ever heard of this happening before?
1 - 11 of 11 Posts
