I’m currently restoring an H1. The shock is definitely rebuildable. Found all the parts needed from different bikes then discovered Bunbury Motor Cycle Engineering. I believe he gets his parts from Shock Treatment, all Racetech gear, somewhere on the east coast. Instead of doing the work myself I gave it to BMCE. The rod had to be rechromed all seals replaced and I asked to have the valving changed, so it was more like a shock absorber, along with a new spring to suit my 70kg weight. Haven’t got it back yet but total quote was less than buying an Ohlins. Sure they’re happy to do yours if you want them to.
Now the rubber stopper. Mines shot too but for about $70 I can buy some polyurethane, machine it up and hey presto it’s perfect. No it’s not rubber and it’s highly likely the original wasn’t either. For the cost of the material I’m happy to make you one. Just let me know.
Oh, for your interest. You’ll also read, or be told, the water pump is not rebuildable. I’m telling you it is completely rebuildable. I’ve rebuilt 2 at a cost of approx $40 each. You will read, in the same article, in order to remove the impeller you need to cut it through 1 side. Then of coarse you will need to weld it up again. On both pumps, I rebuilt, I silver soldered a 6mm nut to the centre of the impeller then screwed a 6mm bolt through it and jacked the impeller off the shaft. Now if you do this the heat will destroy your bearings and seal. No big deal they are likely shot anyway otherwise you wouldn’t need to rebuild it. Again, if you need your water pump repaired I’m happy to do it for the price of the parts and postage to you. The same article will say you can buy the mechanical seal from a later model Kawasaki, but be warned, for about $50 you will only get the stationary half. Mechanical seals are made up of 2 seperate parts. A stationary half and a rotary half. You will need to buy the impeller, from possibly another model, for an unknown price to get the other half. Kawasaki will tell you, for $50, you get the whole seal. You don’t. I have sourced complete seals for under $10.
If you’re interested respond to this and we’ll see what we can do to work out a way of contacting each other. Honestly, while I’m happy to help there’s only so much I’ve got time to do so don’t really want to publish my contact details. Happy to pass the info onto others though so they can do it themselves.
Nice to hear another H1 is being woken up.
Sorry it ended up a novel but it’s difficult when you don’t know the capabilities of the person on the other end of the conversation.
