Whats up guys i wanted to know if kawasaki's were like suzuki's were you can flip the shifter from one down and the rest up to one up and the rest down please advise would be really appriciated. p.m. if you want
VP Whoring
Yup you can.
VP Whoring
There's a couple threads in here that already do. I haven't done it so I wouldn't want to try and explain it. I have just thougt about doing it. Look up reverse shift or motogp shift in the forum.
7777
Another way to do it is get a shifter from a VFR or an Aprilia. I have run an Aprilia shifter. Perfect fit.
To change the stock shifter, remove the front, rotate the end 90 degrees, you then lengthen the shaft until you get the lever where you want it. Only thing I do not like is it feels like it is binding since you have the shaft at such steep angles.
Wait so you cant use the same zx7r flip the part to get it to be reverse gearing and MagicNinja85 there is no thread on this specific topic
