Set them Free! MISSION COMPLETE!
senior member
Are you gonna send them to a preserve or release them into the wild?
Discussion Starter #3
They are being listed on the endangered species list....at the rate theyre being removed!
Discussion Starter #5
Stupid question. Those are what?
All questions are good questions if you are looking for knowledge.
"In fuel injected engines, the throttle body is the part of the air intake system that controls the amount of air flowing into the engine, in response to driver accelerator pedal input in the main. The throttle body is usually located between the air filter box and the intake manifold, and it is usually attached to, or near, the mass airflow sensor.
The largest piece inside the throttle body is the throttle plate, which is a butterfly valve that regulates the airflow.
On many cars, the accelerator pedal motion is communicated via the throttle cable, to activate the throttle linkages, which move the throttle plate. In cars with electronic throttle control (also known as "drive-by-wire"), an electric motor controls the throttle linkages and the accelerator pedal connects not to the throttle body, but to a sensor, which sends the pedal position to the Engine Control Unit (ECU). The ECU determines the throttle opening based on accelerator pedal position and inputs from other engine sensors."
Basically there are 8 "flies", 4 primary and 4 secondary. The secondary, which are removed and pictured above, help to retard the power band on motorcycles at lower RPM's/Speeds by restrictiong airflow.
