Hi guys new rider and new forum member here. I own a 2000, 250 that I bought as my learner's bike last year after taking the MSF course. I was really enjoying it, but its not working again for the second time. The first time I took it to the dealership and had it serviced. The cost was almost as much the value of the bike itself. This time I would like to find a service manual to see if I can repair it myself. I tried Clymer, but they don't have one available for my model. So I would appreciate any help you guys can give me. I don't feel comfortable, moving up yet, since I have not been able to take her out any extended amount of time due to weather, break down issues. Thanks for any help you can give me guys.
cyclepilot
Thanks for the quick reply Shortcircuit. I'll check those both out. The dealership gave me a price 5 times that for Kawasaki manual.
:welcome to the forum Cyclepilot
What is the problem with the bike?
We may be able to help.
Thanks for the welcome guys. When I originally bought the bike it would have a little trouble starting, required full choke and even after starting and warming up for awhile the bike would still turn off whenever I needed to stop. I assumed at that time it was me stalling the bike, eventhough I never had that problem with the bikes in the MSF. After riding for a while this problem would go away. One night while practicing in an empty parking lot the bike stopped even after all of the above. I noticed it was leaking gas, not a lot, but dripping and it was definitely gas. I started it again, but then white smoke starting coming out of the left exhaust, only. Then it died completely and I had to push it home like a couple of miles. I took it to the dealer and they replaced the carburuetor, the gas tank, the battery and a few other small things. All went well for a few months and then on a ride once again the bike just cut off at a stoplight, this time out of the blue. This time on a street, luckily I was able to get it up on the sidewalk and out of the incoming traffic. The bike started back up again, but would begin to sputter if I didn't keep the revs high. I was able to make it back home without having to stop. It stopped again as I was waiting for the gate to open into my apt. complex and I have not been able to start it since then. The lights are still functioning, and it sounds as if the motor is turning over when I attempt to start, but it won't "fire" if that makes any sense to you. I would appreciate any help/advice you guys have to offer. The first service charge cost almost as much as the bike was worth, so I don't want to go the dealer route again. TIA.
First do a couple of basic checks for fuel & spark.
I assume there is fuel in the tank...
If you try to start it, if it does not start, pull a plug & see if it is wetted with fuel or if the exhaust or plug smells of fuel. In theory as they have replaced the tank & carbs fuelling should not be a problem.
Then resting the plug with contact on a metal surface on the engine, turn over the engine to see if you get a spark at the plug. Be careful how you hold the plug so you don't get a shock off the ignition.
Let us know how you get on.
Being in England I gotta go get some sleep, so if anyone else wants to jump in to help, feel free.
