need to know wich zx10r shares the same rod as the zx7r as in the kit item,as iv been told the zx10r rod has the same bearing id's but is a bit longer,as in the same as the kit zx7rr rod,and i just need to have the rod bottom surface ground to the same as the zx7 one as in bottom end width??..it has been done before just need the info.
any help??..need these to run the hi-compression pistons.
