I used a threaded rod and stand off with a hole larger than the bearing . Then I took a washer that would not go into the hole of the bearing , I ground down two sides so it would go in the hole of the bearing . Used the threaded rod and washer to pull out the bearings . It worked fine and I will pull the new bearing back in . Claude thanks for help I needed it . Dan:smile
